11 Users Online (9 Members):
Forums >> Revit Systems >> Technical Support >> PVC Conduit Family
2 Posts No Rating |
I have a normal (pipe) family with center radius based on pipe diameter. Sizing is done through the csv file (lookup table)I need to add several types where the center radius is the same across the different diameters. These can be different family types. How to formulate the read center radius from the initial lookup table to the new types using one label as the constraint? Suggestions?
well if you are using adsks fittings, theyre center radius is linked to the center to end dimensions, so if you simply change the center radius, the fitting will not be able to make the type. i strongly urge you not to use types in your fitting families only because when automatically drawing your piping it may not use the correct fiting based on what is defined in the pipe type. i think i know what you are trying to do, i had to create 59" and 60" radius bends for a specific application but i only needed 4" and 6" conduit.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/ |
Conduit to show hidden under slab |
Wed, Aug 8, 2018 at 11:10:08 AM
Conduit |
Tue, Jan 22, 2019 at 2:22:21 AM
Defining conductor types in Conduit |
Fri, Jan 4, 2013 at 5:12:25 PM
Lost as a goon. |
Mon, Aug 6, 2018 at 2:24:09 PM
2011 conduit connection |
Thu, Jun 10, 2010 at 1:15:54 PM
