Forums >> Revit Building >> Technical Support >> Unwanted printing lines
Sat, Apr 11, 2009 at 6:53:43 PM | Unwanted printing lines
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2009
three fine white lines run through everything i print from revit..
same if printing:
view
sheet
high
presentation
same thing on every printer
Sun, Apr 12, 2009 at 6:13:15 AM | Unwanted printing lines
4 Stars: 205 Votes
Can you please provide more information about this????
Sun, Apr 12, 2009 at 9:28:30 PM | Unwanted printing lines
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
yes thanks typhoon..
it's always been like that with any printer i've
ever had (since revit 8 anyway)..
just print a shaded line view from
revit and see the three fine white lines
running the full length horizontally..
i would be amazed if it didn't do it for
you because it has always done that
for me with many different computers and printers..
try it and if you don't see it i'll scan and post
one for you to see..
Mon, Nov 5, 2012 at 12:10:46 PM | Unwanted printing lines
billgilliss
I reported this to Autodesk technical support in October 2012. They have confirmed that this is indeed a problem, still there in Revit Architecture 2012, and the issue has been forwarded to development for investigation.
I get the white lines when the following conditions are met:
- hidden line or shaded view
- ambient shadows enabled (cast shadows make no difference)
- perspective view
- high-res image, like 5000x3000 pixels. The problem does not occur on small images like 1024x768. The larger the image the more lines I get.
- fairly complex project -- does not occur if there are just a couple of walls and pieces of furniture.
The lines are vertical when the size of the exported image is set to a vertical pixel dimension, horizontal when the the horizontal pixel dimension is set.
Unwanted lines showing through solids
Wed, Mar 16, 2011 at 4:10:46 PM
13
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Lines Greyed-out, but Annotations Not When Printing with CutePDF
Thu, Dec 6, 2012 at 7:52:16 AM
missing lines when printing
Fri, Jul 20, 2012 at 12:17:59 PM
black lines
Tue, Jun 20, 2006 at 12:34:17 PM
Page generation time: 1.4498
