Forums >> Revit Building >> Technical Support >> Angled ends of an extrusion
Fri, Apr 10, 2009 at 8:05:30 PM | Angled ends of an extrusion
twhisker
2.5 Stars: 5 Votes
I have a sunscreen with "L" shaped blades.  I created a family that is fully parametric.  The blades were created with an extrusion and associated sizing and angle.  I loaded it into the suncreen and created an array.  The array will change with the size of the screen and you can choose how many blades to have.  The designer now wants the sunscreens to meet at the corners.  Most corners are 45 degrees - 2 of them are not, so i cannot even hard code this (we will most likely never use this again).  I can angle the support and the outriggers just fine.  I will need some fine tuning so they be parametric - but at this stage hard coded sizes are fine by me.  The issue is that i need to get the ends of the blades to angle as well.  I tried a sweep but that didnt work.  I was thinking of a blend but assume it has to be in the original component.  Take a look - any help would be awesome and as always greatly appreciated.  Thanks.
Revit Architecture 2010
Sat, Apr 11, 2009 at 2:58:05 AM | Angled ends of an extrusion
tim123
4 Stars: 19 Votes
You can achieve this by using a void extrusion in the blade family.  This can also be parametric - it works well if you lock the void to a reference line with an angle parameter.
REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 8:18:33 AM
Adaptive Family - Angled Extrusion
Fri, Dec 23, 2011 at 2:48:55 PM
angled corner joint - how to lock angled corners
Thu, Jul 18, 2013 at 5:10:11 AM
11
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:57 PM
Window with angled sill
Fri, Nov 16, 2012 at 10:49:57 AM
Page generation time: 1.3832
