17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Changing the value of a Length parameter based on the value of a Yes/No paramete
2 Posts No Rating |
Hello: I have a length parameter called "Top Hole True" with a default value of 1/2". I have another parameter, a yes/no parameter, called "Top Hole". I want the value of "Top Hole True" (length parameter) to change to 1" if the "Top Hole" (yes/no parameter) is checked. I thought the syntax would be as follows: Top Hole True = IF (Top Hole = 1, 1", .5" I have read that the number "1" equals "Yes" and that "0" equals "No". The error is, "Improper use of boolean expressions." I use Revit Architecture 2009 Thanks, tykomusic
Top Hole True = If (Top Hole, 1", .5" )
Edited on: Fri, Apr 10, 2009 at 10:22:36 AM
2 Posts No Rating |
Works great...thanks...
'Inconsistent units" error in parameter formula; length vs integer |
Fri, Dec 13, 2013 at 10:37:04 PM
Can a Yes/No Parameter control a Length Parameter? |
Thu, Mar 22, 2012 at 12:17:27 AM
Controlling Length of Floor Based Generic Model |
Tue, Jan 4, 2011 at 12:11:58 PM
Visibility Parameter Formula based on 0.5m Lengths |
Tue, Sep 6, 2011 at 4:59:07 AM
Length Parameter |
Mon, Mar 17, 2008 at 10:44:55 AM
