Forums >> Revit Systems >> Technical Support >> Families In Section View ???
Thu, Apr 9, 2009 at 7:12:42 PM | Families In Section View ???
CKorleski
I am having a problem with one of my families that I have created and viewing it in a section.  I have a family that is made up of 7 large water tanks, any time I try to cut a section isolating only a few or one of the tanks all of the tanks still show up in my section.  I have tryed cutting the section from diffrent sides and regardless of the direction of the section they all continue to show up.  Even if the section start after the tank it will still show up.  Anyone have any idea what is going on???  I am trying to stay away from recreating all the tanks as individual families, but if it si my only option so be it...  Thanks
Fri, Apr 10, 2009 at 7:00:59 AM | Families In Section View ???
Not all families made in REVIT are cutable.  Those families will only show as complete families when you try to cut through them.  Here is the list from the HELP for REVIT architecture.  I'm sure MEP is different.
Cuttable Families
Casework Yes
Ceilings Not Applicable
Columns Yes
Curtain Wall Panels No
Doors Yes
Floors Not Applicable
Generic Models No
Roofs Not Applicable
Site Yes
Structural Columns Yes
Structural Foundations Yes
Structural Framing Yes
Topography No
Walls Not Applicable
Windows Yes
Not Applicable means the category is a system family that cannot be made from a family template.
Edited on: Fri, Apr 10, 2009 at 7:03:01 AM
Fri, Apr 10, 2009 at 10:24:52 AM | Families In Section View ???
CKorleski
Thanks for the response, the tanks fall under the mechanical equipment family type.  I was afrade that I was going to have to re create the tanks as separate families, oh well, have to do what you have to do I guess...
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Missing Objects in Section View
Wed, Jan 14, 2009 at 9:28:23 AM
Section Title View deleted can not recover
Tue, Jun 9, 2015 at 7:48:40 AM
Section view depth
Tue, Jul 15, 2014 at 8:29:07 AM
Page generation time: 0.8670
