Forums >> Revit Building >> Technical Support >> Sketchup to Revit as Family
Thu, Apr 9, 2009 at 3:29:25 PM | Sketchup to Revit as Family
PBR3000
Hi,
 I am designing a diner and am importing some of the less important specialy equipment (IE: Toasters, Microwaves) from Sketchup for interior elevations, equipment plans/schedule etc.
These elemenst show up fine in all views when opened as a family but when inserted as components into the project, they show up as wireframe in plan view (hidden).
Is this a function of cut plane or visibility or is it, as I suspect a bug with the Revit import process?  I am using Revit 9.1.
Any help would be appreciated.  Thanks.
Fri, Apr 10, 2009 at 10:57:05 AM | Sketchup to Revit as Family
afc4
3 Stars: 3 Votes
Do you know if these objests are created using mesh in sketch-up? That would most likely be the cause of the lines in the floor plan view. Since the objects werent created in revit the hidden line wont work with them.
Fri, Apr 10, 2009 at 12:59:22 PM | Sketchup to Revit as Family
erland73
erland73 Avatar
4.5 Stars: 85 Votes
What you can do is to "hide" those lines with a masking region and hidden lines.....
Sketchup to Revit
Wed, Aug 26, 2015 at 10:41:27 AM
Sketchup model into Revit
Tue, Jan 8, 2013 at 12:06:20 PM
Using Sketchup with Revit Architecture
Thu, Jun 23, 2011 at 11:50:30 PM
SketchUp to Revit
Sun, Mar 22, 2009 at 6:53:33 PM
Revit tree family BIRCH - archvision.RPC
Mon, Jan 15, 2018 at 9:59:14 AM
Page generation time: 5.1336
