Forums >> Revit Building >> Technical Support >> Vertical Rail members?
Thu, Apr 9, 2009 at 10:52:32 AM | Vertical Rail members?
elduderino1234
My firm has a type of balcony that we used on a project a few years back. Since then, we have transitioned to revit and I am trying to create this balcony. I have everything built except for the vertical members within the rails (the thin, gray lines in the attacehd pdf). Any suggestions on how to do this? Thanks.
Thu, Apr 9, 2009 at 11:32:47 AM | Vertical Rail members?
tim123
4 Stars: 19 Votes
Create them as a baluster family.  You can model in all the elements, including the support brackets.
Thu, Apr 9, 2009 at 11:40:29 AM | Vertical Rail members?
elduderino1234
So my baluster family will basically be the main baluster, plus the 2 support brackets (top and bottom) as well as each individual vertical rail?
Thu, Apr 9, 2009 at 1:28:16 PM | Vertical Rail members?
elduderino1234
I think I may be getting somewhere with this...
I guess I didn't understand the difference between the posts and main pattern. I'll post back later with some more updates.
Thu, Apr 9, 2009 at 5:25:28 PM | Vertical Rail members?
elduderino1234
I got everything to work except for the C channel at the corner. The rail type is completely different here, as you can see in the break lines in the hand rail. I get an error from revit when I try to create the corner C channel and it says "Can't create geometry for one or more rails." I currently have the C channel created as a rail profile. Any ideas?
rail termination
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail
Thu, Mar 29, 2012 at 8:59:47 AM
Top rail offset
Wed, Jun 21, 2017 at 11:14:51 AM
stair railing baluster properties not consistant with deck rail
Wed, Sep 3, 2008 at 11:08:32 AM
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Page generation time: 0.7422
