Forums >> Revit Building >> Technical Support >> Lighting fixture not showing ANY light
Wed, Apr 8, 2009 at 5:12:25 PM | Lighting fixture not showing ANY light
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Hello there,
Could someone take a look and see why this light fixture isn't working properly?  When I render there is only a hotspot light coming from the fixture.  No matter how long I set the line of light to be??
 The attached images shows (in very low quality) a bunch of these 4' light fixtures next to each other...and all hotspots Sad
Any ideas/suggestions would be very helpful.
Thanks,
Lorne
Denver, CO
Revit Architecture
Thu, Apr 9, 2009 at 2:31:15 AM | Lighting fixture not showing ANY light
tim123
4 Stars: 19 Votes
You can set the length that the light emits from - see image.
Thu, Apr 9, 2009 at 9:22:41 AM | Lighting fixture not showing ANY light
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
See attached.
The first is my properties screen shot.  The second is the light fixture rendered.  And the light fixture family is attached above.  The fixture is 4'-0" long and still shows up as a hotspot?
Thanks,
Lorne
Denver, CO
Revit Architecture
Thu, Apr 9, 2009 at 9:50:59 AM | Lighting fixture not showing ANY light
tim123
4 Stars: 19 Votes
I'm not sure - are you sure it's the same light?  The top light in the image is your light with the 'emit from line length' set to 1200mm and the lower is 300mm.
Thu, Apr 9, 2009 at 10:50:37 AM | Lighting fixture not showing ANY light
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Here's my rendering, family used.
Also, take a look at the Revit file, that is attached to compare the properties with your file.
Thanks for the help,
Lorne
Edited on: Thu, Apr 9, 2009 at 12:23:33 PM
Denver, CO
Revit Architecture
Fri, Apr 10, 2009 at 10:43:35 AM | Lighting fixture not showing ANY light
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I hate to bump this, but I am REALLY trying to get this rednering done and still cant' get rid of these hotspots!
Thanks,
Lorne
Denver, CO
Revit Architecture
Fri, Apr 10, 2009 at 12:09:52 PM | Lighting fixture not showing ANY light
You have a 4' fixture but only a 2' light source.
In addition, your light source seems to be in the wrong place
Edited on: Fri, Apr 10, 2009 at 12:14:06 PM
Edited on: Fri, Apr 10, 2009 at 12:15:38 PM
Fri, Apr 10, 2009 at 12:16:25 PM | Lighting fixture not showing ANY light
Light source
Fri, Apr 10, 2009 at 12:30:55 PM | WWHub
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Quoting WWHub from 2009-04-10 12:09:52"
Edited on: Fri, Apr 10, 2009 at 12:14:06 PMEdited on: Fri, Apr 10, 2009 at 12:15:38 PM"
WWHub,
Thanks for responding.  The Family 'Emit from line length' is 2'-0" in the family.  I still havne't changed that in the actual family.  But the top light 'Emit from line length' is set to 4'-0" in the rendering project (see picture I posted above).
As far as the light source axis in the family.  It may say the axis is in one place but the light source it self is located correctly.  I can change that axis, I was unaware that was mis-located.
Denver, CO
Revit Architecture
lighting fixture basic?
Sun, Oct 16, 2011 at 8:00:31 AM
lighting fixture family
Tue, Jan 11, 2005 at 3:44:52 PM
Lighting Fixture
Tue, Jan 8, 2008 at 7:33:08 AM
Linear lighting fixture
Wed, Sep 2, 2009 at 2:32:08 AM
Creating custom lighting fixtures (What creates the light?)
Sun, Nov 4, 2007 at 1:51:57 PM
Page generation time: 0.7715
