18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Only the outline of the wall shows in coarse, medium, and fine detail. The sheet rock on either side of the metal stud core shows on the interior walls but the wythes of brick don't show in plan. Is there a setting or view component that I have wrong?
62 Posts No Rating |
Check your pahse filters. If set to show complete it should show everything. Including all the details.
These walls are existing walls which, apparently, defaults them to outline only in plan. Seems to me that graying out existing walls is OK, but why not leave the basic detail visible? You were right. It WAS a phasing problem.
CMU + brick wall- brick is NOT bearing |
Tue, Dec 22, 2009 at 3:16:30 PM
Mixing of brick and block patterns and not aligning |
Fri, Jun 23, 2017 at 9:40:16 PM
New Wall with Brick |
Tue, May 26, 2009 at 9:36:24 AM
Brick Wall Recesses - How to properly model? |
Fri, Feb 18, 2011 at 3:08:32 PM
Demo brick on brick/cmu cavity wall |
Wed, Apr 1, 2009 at 12:24:21 PM
