Forums >> Revit Building >> Tips & Tricks >> Modifing Project Elevations: A Tutorial
Wed, Apr 8, 2009 at 11:05:19 AM | Modifing Project Elevations: A Tutorial
LIZARD2806
3.5 Stars: 7 Votes
It happens all the time; the design and modelling begins with partial or no site information, including actual project elevations.  So, we set our first floor at 0'-0" or 100'-0" and get started.  When we do finally get the information, we now have uncoordinated, and inaccurate information on our drawings.
Luckily, this is a pretty straight forward fix that requires just a few simple steps which are outlined below.
1.  Go to an elevation or section view that has your levels visible.
2.  Go to "Tools", "Shared Coordinates->", "Specify Coordinates at a Point"
3.  Select the level line for which you know the elevation for (for example, if you know the first floor is to be 12'-3", select the first floor level line )
4.  In the Elevation box, change the value to the desired value (following the example above, it would be 12'-3" )
5.  Click "OK"
6.  Select any level line and then click the Properties button on the options bar
7.  Click the Edit/New button on the dialogue box that pops up
8.  Under Constraintes, where the option is "Elevation Base", choose "Shared" from the dropdown list.
9.  Click OK to close both dialog boxes.  Your level lines should now show the new elevation heights for the project.
Edited on: Wed, Apr 8, 2009 at 11:06:26 AM
Edited on: Wed, Apr 8, 2009 at 11:06:49 AM
**Using Revit Architecture 2009, 2011, and 2012**
Wed, Apr 8, 2009 at 1:40:36 PM | Modifing Project Elevations: A Tutorial
jdr1281
Thanks great help!
Default Elevations missing in project
Fri, Apr 5, 2013 at 7:21:37 AM
elevations missing
Tue, Jan 24, 2006 at 7:57:13 AM
Lookin for door Group
Wed, Apr 2, 2008 at 4:03:02 PM
New tutorial on sloping roofs
Mon, Jan 5, 2009 at 4:53:58 AM
11
Modifing Wall surface patterns
Fri, Sep 25, 2009 at 8:50:55 AM
Page generation time: 4.2802
