Forums >> Revit Structure >> Technical Support >> Rendering... Block Walls and Floor
Wed, Apr 8, 2009 at 6:30:22 AM | Rendering... Block Walls and Floor
Allan1983a
I am working in Revit Structures 2009 and ahve just figured out how to render.. however I have now a problem that a wall that should be brick and a floor that should be grass is just black, i have changed the properties to what they should be and they display in teh rendering tab as I want them, however when I press render it doesnt work... Any ideas????
I have attached the file so people can play around, and hopefully help me! it is the 3d view I want rendering.
Cheers
Allan
Wed, Apr 8, 2009 at 8:05:02 AM | Rendering... Block Walls and Floor
Allan1983a
please can someone help with this? ive noticed my problems largly goin unanswered recently! they cant be that hard to fix surely!!! lol
Wed, Apr 8, 2009 at 8:13:26 AM | Rendering... Block Walls and Floor
Your model renders fine here.  Under settings / options / renderings, is the Render Appearance library path set?
Wed, Apr 8, 2009 at 8:28:39 AM | Rendering... Block Walls and Floor
Allan1983a
hhhmmmm yes i think so, its set to the assetlibrary_base.fbx is this correct? and the extra render paths are set for more materials, it can see them rigth up until its renders then it doesnt recognise them...
Rendering Split face block in RAC2009
Mon, Jan 12, 2009 at 10:55:20 AM
Rendering cut (scoped) walls - different result each level?
Fri, Jun 9, 2006 at 7:49:50 AM
Arch Walls Block View of Struct Posts
Tue, Feb 11, 2014 at 2:16:47 PM
Beam and block floor problem - cut into wall?
Fri, Nov 30, 2007 at 3:05:02 AM
Room tags, floor marks etc. misplaced in the mirrored plan
Wed, Aug 29, 2018 at 2:37:35 PM
Page generation time: 4.7713
