24 Users Online (22 Members):
Forums >> Revit Structure >> Technical Support >> save central
whats the difference with save & save central ? suddently save central as appeared instead of save. does any 1 know if this is a problem or is it just the same as save ?
If you have a "save to central" available, that is because you have enabled worksets and file sharing. Worsharing enables more than one person to work on the file at the same time. Single user files only have save available. Since this is all new to you, you need to spend some time in your HELP reading up on worksharing, local & central files and worksets before you get in too deep. Come back if you have furthur questions.
also to add to what WWHub said. Once the option is enabled it cannot be un-done. i also say spend some time in the HELP. HTH
3 Posts No Rating |
hi there, in revit programe we have 3 ways to save file 1,"save' tool as the other softwere 2."save as" tool one may creat a new file or use for the first time make central file 3,"save central'tool when we want to workset that sharing file permit we work in team the save central button it is only red when we active workset it is only revit working strongly in group by worksharing regards and good luck TRAN VAN SON
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
Error..wouldn't let me save to Central...help needed |
Wed, Feb 28, 2007 at 9:48:56 AM
can not save a central file |
Thu, Mar 20, 2014 at 2:28:30 PM
"Save to Central" |
Wed, Jan 7, 2009 at 10:19:27 AM
Revit wont save display settings to central file |
Thu, Mar 1, 2018 at 2:53:11 PM
