Forums >> Revit Building >> Technical Support >> Problems viewing railings
Tue, Apr 7, 2009 at 7:14:46 PM | Problems viewing railings
ckchambe
Hello all,
 I'm having some trouble with railings.  I have a raised walkway and I need to cut a plan region through part of it to see what is below.  All other objects disappear from view where I have placed the plan region except the railing.  Is there a setting in the railing that I can manipulate in order to have it obey the view range?
Thanks!
Wed, Apr 8, 2009 at 8:05:36 AM | Problems viewing railings
You may have a problem if a portion of the railing exists in both view ranges - I have not had this condition so I am not sure.  Not sure how you can work around it.
Wed, Apr 8, 2009 at 9:48:54 AM | Problems viewing railings
ckchambe
Yes, that's the issue.  Someone in our office suggested breaking the railing into two and hiding the portion I don't want to see, but I'm hesitant to alter the model in such a way for one view...
Thanks anyway, I appreciate the responce!
Wed, Apr 8, 2009 at 10:01:58 AM | Problems viewing railings
In your VG settings, try unchecking the box under the railings category "Railings beyond cut".  Let us know if that worked.
Wed, Apr 8, 2009 at 1:34:23 PM | Problems viewing railings
ckchambe
Thanks for the tipSmile That looked really promising, but no luck...
I appreciate the help
Wed, Apr 8, 2009 at 2:48:52 PM | Problems viewing railings
tim123
4 Stars: 19 Votes
Perhaps you can use the Masking region if it won't block out any objects below.
Problems attaching railings to stairs
Mon, Dec 2, 2013 at 10:49:14 AM
3D Transparent Viewing
Mon, Jun 9, 2008 at 5:45:00 PM
RAILINGS RAILINGS?????
Wed, Oct 1, 2008 at 3:48:49 PM
Frenc h railings
Wed, Feb 18, 2009 at 2:51:56 PM
11
Interrupted Guardrail with Continuous Handrail - Revit 2013
Thu, Feb 20, 2014 at 12:16:31 PM
Page generation time: 0.1529
