Forums >> Revit Building >> Technical Support >> creating wall openings with void extrusions?
Tue, Apr 7, 2009 at 5:01:12 PM | creating wall openings with void extrusions?
vanderloo
I sure hope Revit 2010 made improvements on wall openings. Since they are currently garbage, I'm trying to create a wall opening by a void extrusion. I've done this before and am not sure why I'm unable to now. When I create the mass, as a void extrusion, give it the proper dimensions. I get "This Mass has no solid geometry for its Void Forms to cut. They must be deleted, or solid geometry added and cut." I know this is simple, but what am I missing? Thank You
Tue, Apr 7, 2009 at 6:41:34 PM | creating wall openings with void extrusions?
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
you have to create an in place family it cant just be a mass.
 modelling/create/walls/void extrusion
Wed, Apr 8, 2009 at 4:51:59 AM | creating wall openings with void extrusions?
vanson
hi there,
there are many way to make the opening for wall in revit, the way you asked
i think you should made a openings family follow these steps
-creat a new window or door familly
-make a opening as a  void form  with the proper dimension
-use cut geomatry stool to cut void and wall together
after that load it into your project
good luck
Creating Solid and Void Extrusions
Thu, Jun 1, 2006 at 10:08:08 AM
Void extrusions
Wed, Apr 8, 2009 at 5:23:38 AM
copying of void extrusions in walls
Mon, Jul 14, 2008 at 2:59:59 AM
my extrusions are transparent?
Tue, Feb 24, 2009 at 5:56:54 PM
Creating Wall Extrusions
Thu, Oct 10, 2013 at 3:37:30 PM
Page generation time: 0.6084
