Forums >> Revit Building >> Technical Support >> Removing constraints on lighting fixture families
Tue, Apr 7, 2009 at 2:52:28 PM | Removing constraints on lighting fixture families
markdstonerii
I have downloaded a lighting fixture on Revitcity that is attached to a wall.  I would like to edit that fixture and instead attach it to massing (rather than the wall).  Can I remove the wall constaint so that the fixture can be attached anywhere?
Please help!
Tue, Apr 7, 2009 at 3:16:17 PM | Removing constraints on lighting fixture families
Sorry - you will have to re-build the family ... or re-create your mass as a wall...
Tue, Apr 7, 2009 at 3:21:34 PM | Removing constraints on lighting fixture families
markdstonerii
When you say "re-build", how would I rebuild it?  Does a family always require a "host" or constraint?
Tue, Apr 7, 2009 at 3:39:12 PM | Removing constraints on lighting fixture families
You can build hosted or non-hosted families.  Just depends on the template you start with.  Light fixtures can be built stand alone/wall/floor or ceiling hosted but can also be defined from generic templates including line and face-hosted families.
Tue, Apr 7, 2009 at 3:57:35 PM | Removing constraints on lighting fixture families
markdstonerii
okay.  That will be helpful on future projects.  Many thanks for your quick response!
face-based lighting fixture families questions [ 1 2 ]
Fri, Oct 24, 2008 at 12:17:51 PM
15
Tagging Lighting Fixture Symbols in RCP
Fri, Dec 18, 2009 at 1:03:01 PM
Lighting Fixture
Tue, Jan 8, 2008 at 7:33:08 AM
lighting fixture basic?
Sun, Oct 16, 2011 at 8:00:31 AM
gym lighting fixture
Tue, Jul 22, 2008 at 2:20:59 PM
Page generation time: 1.3719
