21 Users Online (19 Members):
Forums >> Revit Structure >> Technical Support >> new parameter to veiw title.rfa
7 Posts No Rating |
How do you add a new parameter to the ‘view title.rfa’. When you open the family for editing and open element properties under label – edit, you have a list of parameters (such as ‘view name&rsquo . The parameter I would like to add is ‘title on sheet’. This parameter is found in the project file under the browser when you right click a detail to bring up the element properties under ‘identity data’ you have ‘view name’ (which is the default when you pull the detail on to a sheet) and ‘title on sheet’. So how do I get the ‘title on sheet’ parameter listed in the ‘view title.rfa”
View Name is the proper pick. Revit will automatically pick the view name or the name on sheet if that is filled in.
My wishlist: Adding parameter in VIEW TITLE rfa |
Tue, Mar 20, 2012 at 4:55:00 PM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
View Discipline Parameter |
Mon, Mar 4, 2013 at 3:08:40 PM
How do you share a parameter between several different sheets? |
Thu, Nov 10, 2016 at 3:15:54 PM
Add Parameter to Family Category - View Title |
Tue, Jan 17, 2012 at 2:28:48 PM
