Forums >> Revit Building >> Technical Support >> Hide sweeps--
Tue, Apr 7, 2009 at 10:15:36 AM | Hide sweeps--
epepa
Is there a way to hide sweeps in floor plan views without deleting the sweep itself? I've tried unchecking the box in Visibility/Graphics, but it doesn't seem to do anything. Any suggestions?
Tue, Apr 7, 2009 at 1:06:33 PM | Hide sweeps--
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
select sweep; right click; select hide in view.
Thu, Apr 9, 2009 at 8:56:03 AM | Hide sweeps--
epepa
In plan view, if I try to select a sweep, it select the whole wall associated with it. Thus, when I select "hide in view", it hides the entire wall, so unfortunately, your solution does not work.
Thu, Apr 9, 2009 at 9:00:57 AM | Hide sweeps--
It sounds like your sweep is part of the wall definition - is that true?
In other words, it is not an applied sweep - that is why I think you can't hide it seperately.
Hidding Wall Sweeps in Plan [ 1 2 ]
Thu, May 11, 2017 at 4:17:56 PM
18
Problem connecting wall sweeps (horizontal and vertical)
Fri, May 4, 2012 at 2:07:26 PM
Angling Wall Sweeps
Profiles and Sweeps - Hiding lines within the sweep
Fri, Apr 25, 2014 at 11:39:53 AM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Page generation time: 0.4564
