Forums >> Revit Structure >> Technical Support >> Rendering problems.....again!
Tue, Apr 7, 2009 at 5:08:30 AM | Rendering problems.....again!
Allan1983a
I have created a camera view that I wish to base my render on and run the render setting, however all I end up with is a black screen.... I have tried everything I know to fix it, can somene please help me here!!!!!
Tue, Apr 7, 2009 at 7:27:50 AM | Rendering problems.....again!
Do you have any lights on...really stupid question but you don't give us many clues to work with.  Screenshots of your settings always helps.
You might tell us a bit about your system - memory etc.  Tell us about your process.... is it wham - black screen & your done or does it sit and work awhile then nothing? Is REVIT done ... you can start a new command or is it froze?
Rendering is very memory intensive and your system does not release all memory back as you work.  Do you start a render session from a clean startup of Revit?
Tue, Jun 7, 2011 at 10:31:36 AM | Rendering problems.....again!
dpllewis
I know it's been a while since the last post, but if anyone else ends up here because they are getting 100% black renders I can strongly suggest the same, that is to say saving the project, closing Revit and starting it again. Seems the application is sensitive about memory and needs a refresh sometimes. This worked for me using Revit 2011.
Problems with Best quality nighttime rendering.
Tue, Dec 4, 2012 at 8:32:13 PM
Rendering Problems
Wed, Jun 18, 2008 at 6:48:29 AM
12
Rendering problems
Tue, Sep 12, 2017 at 9:55:21 AM
help with rendering!
Wed, Aug 10, 2016 at 10:47:17 PM
Can a 63mb Revit File Size cause problems during rendering?
Mon, Nov 2, 2015 at 6:29:45 AM
Page generation time: 0.2402
