Forums >> Revit Building >> Technical Support >> one roof two wall heights
Mon, Apr 6, 2009 at 7:49:57 AM | one roof two wall heights
JARDesign
JARDesign Avatar
5 Stars: 2 Votes
Simple one, I can't figure out...
I have a roof that has bearing walls at two different heights... How do I set that?
Mon, Apr 6, 2009 at 9:02:22 AM | one roof two wall heights
tim123
4 Stars: 19 Votes
Is the roof in one plane, with one bearing wall set back further than the other?  If so, just set one as slope defining.
Mon, Apr 6, 2009 at 9:15:29 PM | one roof two wall heights
ScopeDrafting
I found this clip helpful in showing different wall heights with same roof.
 Basically you have to create a different roof for each wall height and join them up.
http://www.dgcad.com/downloads/CADCLIP-REV-VARYING-ROOF-PLATES.wmv
Mon, Apr 6, 2009 at 11:34:59 PM | one roof two wall heights
dnicholson
thanks so much for posting that vid,  its saved me!!  been getting very frustrated trying to do this, ended up massing the whole thing which sucked.  thanks.
On a similar note, you can set different heights in the properties for each line when creating a roof.  but it seems to fail every time you try putting a different one in there.  pointless having an option in there to break your roof no?
Wall heights - change all heights simultaneously
Wed, Sep 7, 2011 at 7:43:24 AM
Roof with different heights
Mon, Nov 11, 2013 at 7:35:51 AM
Why do all my Wall Heights default to 20'-0" !!
Wed, Apr 26, 2006 at 4:31:21 PM
Roof with different eave heights
Mon, Aug 20, 2018 at 2:36:33 PM
Roof Plate Heights
Wed, Apr 11, 2007 at 6:20:00 AM
Page generation time: 0.6662
