Forums >> Revit Structure >> Technical Support >> Group selection
Mon, Apr 6, 2009 at 7:23:14 AM | Group selection
Murox
Murox Avatar
Hello I have a problem about selecting groups in an elevation view. I'm able to select it in a floor plan but it's impossible in the elevation view called "North". Tanks a lot for your reply !
Carl Veillette
Nothing is impossible ...
Mon, Apr 6, 2009 at 9:55:04 AM | Group selection
Is the group really in the view?  If so, have you tried using your tab key?
Sorry for these questions but your question is not well defined.
Mon, Apr 6, 2009 at 10:04:22 AM | Group selection
Murox
Murox Avatar
Forget about that I  found the problem was in the view proprieties "Delimitation without line" must be selected to pick a group in an elevation view ...
tanks !
Carl Veillette
INSERTED GROUP - COPIED GROUP - DIFFERENT RESULT [ 1 2 ]
Wed, Nov 23, 2016 at 3:27:29 PM
15
Error Message when i try moving curtain wall in a group
Mon, Mar 18, 2013 at 12:46:57 PM
Detail Group Partial Visibility
Fri, Jul 15, 2016 at 10:37:44 AM
Selection Box Doesn't Include Ceilings
Tue, Jan 8, 2013 at 3:51:20 PM
selection issue
Fri, Mar 4, 2005 at 3:43:11 PM
Page generation time: 0.9795
