Forums >> Revit Building >> Tips & Tricks >> Help Family
Mon, Apr 6, 2009 at 4:10:46 AM | Help Family
trandung
Hi all
I created this family for door . The curve swing angle , I can not finish them ! Help me
Thanks
Thu, Jun 18, 2009 at 12:50:09 AM | Help Family
TimProof
Exactly what are you after? are you wanting to be able to adjust the door swing angle?
You had your glass width as '=(Width - (Do * 2)) / 2' Try '=(Width / 2) - (Do * 2)'. Personally I tend to make a parameter called 'Panel Width' '=Width/2' in this case and the glass formula '=Panel Width - (Do * 2)'
I have modified the file you posted. See if that is what you wanted. I have made ONE of the door swings work, the other you can learn with!
 Just so you know. You can assign lines or geometry to reference lines. To do this, select the line/lines/object and click the 'edit work plane' button in the options bar. select the 'pick a plane' option and select the reference line you want to associate to. Now rotate that line (or assign an angle to it) and the attached geometry/lines will move with it! This is what I did with theRightmost door reference line (the green one). For the swing arc, I drew a curve using the line tool, the going into its properties, checked the 'center mark visible'. This makes the center of the curve appear. This can be aligned and locked to reference planes (as I have done in you door). the curve is then adjested to size (600mm) andaligned to the door.
Personally, I prefer to make a detail item of the door in plan, load it into the family. that way it acts as one piece and can bemanipulated easier, without falling apart, or breaking constraints.
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Can you use an IFC file in a family. or use one like a family?
Tue, Aug 7, 2012 at 4:27:00 PM
14
Detail Family Line weight sub-catoagories gone when family put into project
Tue, Aug 30, 2016 at 6:52:17 AM
11
"Can't Regenerate Family ____. Edit Family to modify it." Error message
Wed, Aug 26, 2020 at 11:19:36 AM
Text(family #1) not showing after loading into family #3
Mon, Jan 19, 2015 at 2:43:21 PM
Page generation time: 0.9789
