26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Material Orientation Problem
2 Posts No Rating |
I am having a rendering problem where the material (in this case brick) rotates 90 degrees on different faces of an object. The brick is supposed to be horizontal all the way around the column, but rotates on the front face. The object is a solid form in a wall hosted family. Any help is appreciated.
Rotate the fill pattern. Select one of the pattern lines (you might need to use the tab key to select it) and rotate it. Dependinf on how it was created, you might need to go into the family to rotate it.
2 Posts No Rating |
I actually didn't even have the fill pattern turned on for the material. All I had to do was turn it on and problem solved! Thanks!
2x4 ceiling grid orientation |
Mon, Aug 7, 2006 at 8:53:22 AM
MAterial texture orientation |
Fri, Mar 17, 2017 at 9:29:03 AM
printing orientation problem |
Thu, Jul 5, 2007 at 7:05:47 PM
ARCHITECTURAL COLUMNS MATERIAL PROBLEM |
Thu, Jan 22, 2015 at 10:08:27 AM
3D View orientation won't lock |
Sun, Feb 26, 2012 at 7:44:07 PM
