19 Users Online (17 Members):
Forums >> Community >> Newbies >> Walls
Does anyone know how to attach a wall to a grid/slab, have tried the attach/detach button but it doesnt seem to work when I move the grid. I have also tried to pin it but it just seems to keep it in the position that its in and not move it with the grid
let me take one by one if u want to attach a wall to the grid then just dimension it and lock the wall to grid. Thereafter u can delete the wall but the constraint will be there. Wall can be easily attach or detach to the slab by clicking on option. See attached snapshot Hope this helps. Cheers
Now on the implementation stage.... |
If you use the align tool to line the wall up with the grid you have the option of contraining it (padlock).
thanks for your help guys
Edited on: Thu, Apr 16, 2009 at 11:27:41 PM
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
