Forums >> Revit Building >> Tips & Tricks >> Ceiling height in Room Schedule
Sun, Apr 5, 2009 at 12:44:47 PM | Ceiling height in Room Schedule
jarosa
jarosa Avatar
4 Stars: 5 Votes
In case you didn't know already. In Revit 2009 rooms have a parameter Limit Offset. You can use this in the Room Schedule for Ceiling Height. You will need to make sure your ceilings are set to the same height as the room Limit Offset so your Ceiling Tag with Height will match your Room Schedule.
John
Room schedule with ceiling height
Fri, Jul 13, 2007 at 11:01:42 AM
Add Ceiling Height in Room Schedule
Mon, Nov 19, 2012 at 9:38:54 AM
CEILING HEIGHT IN SCHEDULE
Mon, Feb 18, 2019 at 6:34:48 PM
Can the room schedule have a column that automatically fills in ceiling height?
Fri, Jul 13, 2007 at 11:53:52 AM
Room Schedule-Can I get the ceiling height to be automatically calculated?
Mon, Sep 22, 2008 at 10:46:23 AM
Page generation time: 1.1164
