Forums >> Revit Building >> Technical Support >> HVAC, Any Ideas?
Sun, Jul 3, 2005 at 8:48:41 PM | HVAC, Any Ideas?
ale02
ale02 Avatar
3 Stars: 3 Votes
Guys, Anyone of you have experiences working on HVAC ducts and other utilities pipes? Since we still await Revit Mechanical to be on-board...properly I just need to ask which is the better/ fast way to work around it at the moment, as HVAC ducts have a lots of duct reducers and bends and run in different levels.... in-place family or create family with instance parameter, which is better? Thanks in Advance.
Life is never easy but nor it should be complex. Just stay simple Smile
Sun, Jul 3, 2005 at 9:32:40 PM | RE: HVAC, Any Ideas?
eldados
eldados Avatar
4.5 Stars: 8 Votes
I would create an external family with height width and length, it's easy to do, same with the bends though, if you have a few of them it will be a bit time consuming (you need to do it once) if you don't really need to show the bends, i would not worry about it, just the ducts in place...
Mon, Jul 4, 2005 at 3:36:13 AM | RE: HVAC, Any Ideas?
ale02
ale02 Avatar
3 Stars: 3 Votes
Hey, I just got another Idea, properly it is worthwhile to import the while ducting ACAD drawing over the family and create the whole ducting as a family, then only import it over to the project....In project, I only have to assign the datum level and the whole ducting family will go according to it location..align, move bla bla bla. and I get rite of my worries for the level and bends working in projects which is somehow confusing!! Only negative part of this idea is only dedicated for this project and the family won't be able to be reused later.
Sat, Feb 25, 2017 at 10:05:24 PM | HVAC, Any Ideas?
Iceman5000
Anyone in HVAC want to model a good looking name brand furnace?  Do they have them on RevitCity?
2014 HVAC and Plumbing shows on ribbon but no Electrical - All are checked
Mon, Mar 7, 2016 at 3:55:02 PM
HVAC Ventilation Outside Air
Tue, Jan 8, 2013 at 10:15:50 AM
Mechanical HVAC Thermostat?
Mon, Mar 9, 2009 at 4:45:07 PM
viewing structural, architectural & hvac in 3d with shading and edges
Tue, Apr 20, 2010 at 5:53:58 AM
HVAC Diffuser will not print
Wed, Jul 23, 2008 at 12:48:12 PM
Page generation time: 0.1081
