16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Corner angles
fine as long as everything is straight up and down.. RAC2009 please see the images of this airport tower i'm trying to build.. where the glass angles and sits on an angled base and joins at the corners and has been hours and hours of mish-mashing generic model elements.. how would anyone even attempt something like these kind of angles?
Create the walls as a blend - the illustration shows the first made as one blend and the second made as two blends - which gives greater control over the material orientation. For the glazing, consider how this would actually be constructed. You will have to have some kind of join here, even if its a gasket or silicone. The galzing can be created in the same way as the walls - blends, or as sloped glazing. Create new mullions for the gasket joins.
thanks so much for reminding me about the blend.. the joy that brings is unbelievable.. of course it helps to be a little crazy like me.. see the image and all i did was create a big blend with a big void in the center.. i have no idea how i would create a slanted curtain wall in there though.. if you have any ideas on that let me know.. but i'm so happy right now..
You can create it in the same way as the walls or create it as a mass using the blend and select the faces to be curtain walls or create it as an inverted roof and change it to sloped glazing.
Corner windows with variable angle |
Tue, Dec 27, 2016 at 4:47:10 PM
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
corner windows |
Tue, Jun 3, 2008 at 10:56:06 AM
REAL Corner boards |
Thu, Oct 27, 2005 at 3:51:59 PM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
