24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Yes No parameter?
126 Posts No Rating |
Working in 2008 and cannot seem to get the yes no parameter to work. I want to be able to turn a shutter on and off. I have a window family that has this feature and tried my best to do the same with my door family but there is a step or something I am missing. I have created the parameter and set it all up but not sure how to get the actual shutter associated with the parameter. Any help or suggestions would be greatly appreciated. Thank you, Raina Mc
you have to selected the geometry in the family editor that you want to be able to turn on and off, then go into its properties and there is a small button in the right margin of visibility that you can barely see that will allow you assign the parameter. you wont be able to see it turn of til it is reloaded sorry I keep effing up my html
Edited on: Fri, Apr 3, 2009 at 5:55:00 PM
Thank you! That was exactly what I needed.
Can a Yes/No Parameter control a Length Parameter? |
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Add angle parameter to generic annotation with offset parameter |
Mon, Mar 2, 2020 at 12:57:06 AM
Add Family name to a shared parameter |
Tue, Jun 23, 2015 at 8:50:48 AM
NOT Parameter Formula Question |
Fri, Apr 10, 2009 at 8:30:17 AM
