22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Elevation Tag with same name
Ok Today's problem.... In my building section I have two elevations for T.O. CMU. Normally you would have a elevation tag for both levels and label them the same. So I went to my building section copied a level elevation tag(Made sure that it did not create a level) moved to the desired heigtht and tried to change the name. Of course the programers for Revit never thought that you might need to have two elevations named the same so they made every level need a unique name. So I try and enter a symbol but the elevation tag is not a symbol and would not let me insert it. What have people been doing to get around this problem.
Your problem is nomenclature. Level to REVIT is something like a floor plane or main structural plane like roof bearing. What you are talking about is s pot elevation. Try using the target filled one to start. You can modify that so that you can add your TO CMU tag.
Beam Tag with Top of Steel Elevation ? |
Fri, Aug 1, 2014 at 8:12:42 AM
Interior Elevation Tag missing from drop down |
Wed, Aug 18, 2010 at 4:28:45 AM
updating/changing elevation tag types |
Wed, Mar 19, 2008 at 9:49:46 AM
Elevation tag |
Thu, Nov 1, 2007 at 3:06:21 PM
if I happen to put two elevations on different sheets on the same elevation tag |
Wed, Jan 12, 2011 at 3:00:58 PM
