Forums >> General Discussion >> Revit Project Management >> Pasting Details
Fri, Apr 3, 2009 at 5:36:13 AM | Pasting Details
albertstwrt
4 Stars: 8 Votes
I'm a drafting student at a Community Collage, trying to complete a project in revit. So I ask. Can I past a PDF file into Revit? Or should I redraw the file in view_drafting views? You see, it came from a railing company that doesn’t have BIM files. Atlantis Railings.
If this is possible, is there some way I can take just the drawings and text? Or should I leave the title blocks?   THANK YOU.
Fri, Apr 3, 2009 at 6:15:35 AM | Pasting Details
MikeChan
3 Stars: 5 Votes
you cannot import PDF directly into Revit, but you can convert the pdf to other file format which can be imported to Revit.
Redraw in drafing view, if just 2D line drawing, is a good option for u, being a student you better learn how to use the program while you have the chance.
Fri, Apr 3, 2009 at 10:43:21 AM | Pasting Details
albertstwrt
4 Stars: 8 Votes
Thanks…..But out of curiosity what will be those other options? I’m trying to engage in all aspects of the program. At this point, I’m having a little trouble with detailing. That’s why I’m asking about the option’s you mention. So I can load them into my arsenal. Can “dwg., dxf., dgn., sat. and skp.”, be included  in converting from PDF? Will I need special software to accomplish this? Or just  AutoCad? And on detailing, I may have over looked something in the tutorial. Thanks a trillion Mike.
Fri, Apr 3, 2009 at 4:26:23 PM | Pasting Details
MikeChan
3 Stars: 5 Votes
Depend on the PDF, because pdf can be raster image or vector. if the pdf is vector format, you can convert it to dwg or dxf, but if the pdf is raster image, you will need to convert it to jpg or png image format, Revit can import them.
Search on web to see which program suit you, sometime you might can find freeware or demo converting pdf to dxf or jpg format.
Fri, Apr 3, 2009 at 7:50:10 PM | Pasting Details
albertstwrt
4 Stars: 8 Votes
drafting details
Fri, Feb 19, 2010 at 7:08:37 AM
query with elevation details
Mon, Dec 1, 2008 at 5:12:35 AM
Shared Details
Wed, Sep 17, 2008 at 10:35:49 AM
Typical Details
Thu, Aug 28, 2014 at 7:54:38 AM
How can I radius my coping of steel beams?
Mon, Oct 25, 2010 at 5:02:18 PM
Page generation time: 1.7231
