23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Detail Groups NOT DELETING!
12 Posts No Rating |
(Revit 2009) I am trying to clean out a Template file. There are 4 detail groups that refuse to be deleted. I have tried everything I can think of. I have tried to right-click "Delete" them. I have tried right-click "Select All Instances" then Delete them. And I have tried Purging. When I go to right-click "Delete" or "Select All Instances" the options are grayed out (See attached Picture #1). When I go to Purge the Detail Groups there aren't any Detail Groups listed (See attached Picture #2). Does anyone know what is going on?
Edited on: Thu, Apr 2, 2009 at 3:12:16 PM
Sorry, These are the Files that will work....
Try running an audit to see if that helps. I assume that you tried to purge but since its in the file i doesnt show up. the other thing i could say to try is to do a save as and see if that helps anything.
Okay, I just figured it out. Turns out that the detail groups that I wanted to delete were inside a Legend. (I don't know why they were in there to begin with? and Why couldn't I use "Select All Instances" to select them? I have no idea....
Your attachments don't really tell us anything. I suggest you look for these groups being buried in something else.... possibly another group.
Array Groups within Detail Groups |
Tue, Jul 9, 2013 at 7:34:32 AM
Attached detail groups missing from model groups... |
Mon, Aug 17, 2009 at 8:11:10 AM
RAC 2009 - detail groups and section detail blow-ups |
Fri, Mar 26, 2010 at 8:50:53 AM
Delete detail groups? |
Wed, Apr 10, 2013 at 8:51:18 AM
Groups and Phases |
Thu, Jan 29, 2015 at 10:45:27 PM
