Forums >> Revit Systems >> Technical Support >> Pendant light mounted to sloped ceiling
Thu, Apr 2, 2009 at 1:18:40 PM | Pendant light mounted to sloped ceiling
chuckbradley
I want to make my lights have the ability to offset from a sloped ceiling and automatically tilt to a vertical plane so they appear to hang with gravity.  Right now they hang at a 90 angle to the ceilings.  Families are face based.  Basically it seems I need to lock objects in but allow the host face to tilt.  This "technology" could eventually add the ability for me to put objects on most any angle of surface and have they annotations show up in plan.
It didn't seem possible when I tried it so I'm looking for some help.
Thanks!
Thu, Apr 2, 2009 at 2:59:08 PM | Pendant light mounted to sloped ceiling
Open your light family and under settings / categories & parameters and uncheck the always vertical box.
Now reload the family - go to the appropriate view and rotate your light to vertical.
Mon, Apr 6, 2009 at 2:21:34 PM | Pendant light mounted to sloped ceiling
chuckbradley
Thanks, but that is not an option for light fixtures.
In any case, I would like the light to hang down automatically, no matter the ceiling angle.  There is probably some data extraction and a formula involved here.
Tue, Apr 7, 2009 at 9:33:15 AM | Pendant light mounted to sloped ceiling
chuckbradley wrote "Thanks, but that is not an option for light fixtures."
LOOK AGAIN - You are absolutely wrong!
Tue, Apr 7, 2009 at 1:03:37 PM | Pendant light mounted to sloped ceiling
chuckbradley
I appreciate your help, even though you are absolutely incorrect.  At least as far as what I'm looking at on my screen. Smile
Under Settings-Family Category and Parameters, there are only 3 parameters available for Light Fixtures. Light Source, Part Type and Shared.
MEP09 is the software version I'm using.
Thanks again.
Tue, Apr 7, 2009 at 1:19:46 PM | Pendant light mounted to sloped ceiling
Thread Post Kudo! #6
Well, maybe something different in MEP - here is Architecture 2009.
This is just a lighting fixture - ceiling based has the same GUI.
Tue, Apr 7, 2009 at 1:47:28 PM | Pendant light mounted to sloped ceiling
chuckbradley
The difference is yours is a Ceiling Based light fixture.
We are using linked architectural models, so everything has to be "face based" or it will not place on the surface.
Thanks again!
Tue, Apr 7, 2009 at 2:07:45 PM | Pendant light mounted to sloped ceiling
NO - as I said, this is just a light fixture ......  ceiling based has the same GUI.
BUT NOW WE KNOW THE REST OF THE STORY!  You used a generic model (face based) template - not  a lighting template.  If you had given that information eariler, we could have saved a lot of time.
Faced based generics may work best for what you are doing but you could have used just a light fixture and aligned it to surfaces.
Tue, Apr 7, 2009 at 2:23:58 PM | Pendant light mounted to sloped ceiling
NKramer
4 Stars: 9 Votes
This is the only other way to do it....
It took me about a day to get this working, but I would be happy to sell it to you Smile
Nick
Wed, Feb 17, 2010 at 3:54:28 PM | Pendant light mounted to sloped ceiling
jmqrsq
5 Stars: 3 Votes
sell it to me? how about just some freindly help on how you made it?
Wed, Feb 17, 2010 at 6:04:20 PM | Pendant light mounted to sloped ceiling
#11
dano3d
3.5 Stars: 3 Votes
Here's a ceiling fan that always stays vertical.
It's "ceiling based", so make sure you have a ceiling system to attach it to.
Hope it helps you.
Dano
Wed, Feb 17, 2010 at 7:55:31 PM | Pendant light mounted to sloped ceiling
#12
NKramer
4 Stars: 9 Votes
Get a family started, use the screen shot and formulas and see where that takes you. I would be happy to help trouble shoot or work on a family. Or sell it if you want it done for you. Smile
Nick
Wed, Feb 2, 2011 at 5:49:18 PM | Pendant light mounted to sloped ceiling
#13
yuliavsan
NKramer - Can I get your sloped ceiling family? I typed in everything from your attacment and it doesnt work for me. Please help.
Edited on: Wed, Feb 2, 2011 at 6:41:21 PM
Tue, Oct 30, 2018 at 8:37:08 PM | Pendant light mounted to sloped ceiling
#14
bitslap
7 years later...
I wanted accent lights for landscape lighting, and from a youtube clip:
1. Created ceiling-based light from template (be sure to uncheck 'Always Vertical' - you can't do it later)
2. Placed light family on ceiling in new project and saved project.
3. Linked saved project into new, empty project.
4. Clicked 'Collaborate->Copy/Monitor->Select Link' and clicked the linked project.
5. Clicked 'Copy' then selected the ceiling light, then 'Finish'
6 The light is now in the empty project as a face-hosted light, anchored perpendicular to the host.
Pendant Lights on a sloped ceiling
Thu, Sep 12, 2013 at 9:19:42 AM
Pendant light placement
Wed, Sep 19, 2007 at 4:03:08 PM
Revit 2013/2014 Linear Pendant light fixture
Fri, Nov 1, 2013 at 10:45:44 AM
Ceiling mounted light family
Tue, Feb 1, 2005 at 9:04:23 PM
Light Fixture on Sloped Ceiling Displays incorrectly in section
Wed, Jun 1, 2016 at 6:43:11 PM
Page generation time: 1.5454
