17 Users Online (15 Members):
Forums >> Community >> Newbies >> Fish Scale Siding
3 Posts No Rating |
Is there a known fish scale siding pattern to use in the model. If so can you tell me how to download it. Thanks,
Look in the downloads "patterns" and there is something close.
3 Posts No Rating |
Thanks, I tried that and cannot find it. however I used a pattern I had not the only problem is that it is upside down.
IF IT IS A MODEL PATTERN, YOU SHOULD BE ABLE TO ROTATE IT. Otherwise, edit the file and add this as the second line ... right after the title ;%TYPE=MODEL Now re-load this as a model pattern and it will rotate. BTW - this is just a txt file and you must keep it that way .... just use wordpad
3 Posts No Rating |
Thanks, got it. I was having a hard time getting the pointer to select the pattern to rotate it.
Hatch Patter - Fish Scale |
Tue, Nov 17, 2015 at 10:54:33 AM
Metal siding |
Mon, Mar 16, 2009 at 9:44:10 PM
Wall Sweep/Siding |
Sun, Feb 17, 2008 at 12:11:00 PM
Siding Sweep Return |
Sun, Oct 30, 2011 at 5:57:53 AM
Walls with siding |
Tue, Feb 28, 2006 at 5:21:50 PM
