26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Unable to view RCP
2 Posts No Rating |
Hi wonderful Revit masters! I am using the student version of Revit 2009 to do a school project. I have a 3 floor building and am able to both work and view my RCP's on the first and second floors, however can not even pull up the RCP for the 3rd floor. Does anyone have any suggestions as to why this is happening? Thanks so much! You guys are great!
is there a view created for the third floor? if not goto the view pull down--> New--> Ceiling Plan and check level 3. If that is not the case check the view range for the third floor.
2 Posts No Rating |
There is an RCP for Level 3, I just can't get it to show up. How do I go about checking the view for that level? Thank you!
Right click in the view and goto VP( view properties) and the goto view range and see what the numbers are, Or you could just apply a view template to the view to get it back to a default RCP.
Unable to place lighting on RCP |
Thu, Dec 16, 2010 at 1:39:42 PM
Fri, Jan 9, 2015 at 10:44:18 AM
Rooms in RCP |
Tue, Mar 23, 2010 at 9:47:54 PM
see RCP on plan view |
Mon, May 17, 2010 at 4:50:56 PM
view range wont adjust in RCP |
Wed, Jan 31, 2018 at 3:44:20 PM
