Forums >> Revit Building >> Technical Support >> Demo brick on brick/cmu cavity wall
Wed, Apr 1, 2009 at 12:01:57 PM | Demo brick on brick/cmu cavity wall
masterbrewer
Is it possible to only demo the brick or a portion of the brick on a brick/cmu cavity wall?  I've only been able to show the entire wall as demo.
I'm using Revit Arch 2009.  Thanks!
Wed, Apr 1, 2009 at 12:23:52 PM | Demo brick on brick/cmu cavity wall
afc4
3 Stars: 3 Votes
split the wall so that you can make a section that you wish to demo. Or create an opening and add in the same wall type in the open space, and demo that piece.
Wed, Apr 1, 2009 at 12:24:21 PM | Demo brick on brick/cmu cavity wall
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Sorry masterbrewer,  the way I have achieved this in the past is to create a wall that is brick only and embed it into the brick over cmu, then demo the brick, thus leaving the existing cmu behind. I only needed to do this in areas where I was keeping some brick.
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:30 PM
Hello Newbie here, brick on brick on cmu wall type doesn't show up
Thu, Jan 27, 2011 at 1:06:15 PM
Demo issues?
Mon, Oct 12, 2009 at 1:30:38 PM
Brick wrap around the top and sides of CMU wall
Tue, May 10, 2016 at 10:04:28 AM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Wed, Apr 8, 2009 at 5:08:39 PM
Page generation time: 2.2855
