Forums >> Revit Building >> Technical Support >> Why is this doing this? - I didn't ask it to do this....
Tue, Mar 31, 2009 at 10:42:44 AM | Why is this doing this? - I didn't ask it to do this....
IloveSKETCHUP
Why or why is this doing this? - coloured structural beam lines
after i apply my view template to a linked structural file, the beam lines change to colours like the images.
any ideas why this would be doing this?
my view template customized the linked file so that annotation cataegories - ref lines, grids, leveles, tuned off.
Tue, Mar 31, 2009 at 12:18:59 PM | Why is this doing this? - I didn't ask it to do this....
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
The orange lines are the analytical lines of the structural model.
You can turn these off by going into your view templates and then into VISIBILITY / GRAPHIC OVERRIDES FOR PLAN (maybe check other view types) and check the SHOW CATAGORIES FROM ALL DISCIPLINES, in the bottom left corner.
Then expand out the structural framing catagory and uncheck analytical model...it should be the first opton.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Attached image didn't come thru for wall question.
Mon, Jul 17, 2006 at 10:14:26 PM
Don't know why i didn't think of this sooner....
Mon, Oct 13, 2008 at 12:53:08 PM
Second plea for help! No response so far!
Wed, Jul 18, 2007 at 1:53:57 PM
Problem import Autocad file that contains ''proxy entities''.
Wed, Mar 17, 2021 at 7:38:19 AM
Average Estimated Illumination didn't work on schedules
Mon, Dec 11, 2006 at 1:39:12 PM
Page generation time: 0.3341
