Forums >> Revit Building >> Technical Support >> Site Orientation
Fri, Jul 1, 2005 at 11:48:17 AM | Site Orientation
chawley
Is there a way to adjust the orientation of the site without rotatating it? For example I am modeling the building and the front entrance is labeled south. The reality is that the front of the building actully faces northeast. I understand I could rotate the enire model 135 degrees clockwise but I was wondering if there is a way I could rotate the "north arrow" 135degrees instead making future modeling modifications and page layout easier. Input would be greatly appreciated. Thanks Chuck
Fri, Jul 1, 2005 at 12:30:35 PM | RE: Site Orientation
vdogg
There is the TrueNorth/Project North Option you can go with. We sometimes just rename the elevations for the direction it actually faces.
Fri, Jul 1, 2005 at 3:52:38 PM | RE: Site Orientation
chawley
Thanks. That was a lot easier than I thought it would be.
site orientation
Mon, Feb 18, 2008 at 1:35:35 AM
Building Orientation on a site
Thu, Feb 15, 2007 at 10:07:42 AM
Linked Revit model not importing in the correct orientation
Fri, Nov 20, 2015 at 4:00:35 AM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
add orientation to window schedule
Mon, Feb 3, 2014 at 7:23:49 AM
Page generation time: 3.2253
