27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Importing Cad Files
Hi, I'm trying to import some variouss CAD files in .DWG format into revit and make them into a family. Originally the files all came from .3ds files, so i had to import them into autodesk 3ds max design 2009 and then export them as .dwg files so i can import them into revit. Everything went smoothly until i realized that the individual pieces of the imported objects no longer had seperat materials, the whole object is just one plain color, Even though in 3ds max design 09 i assigned every piece a material. Are materials non transferable??? is there a better program to use?? am i doing this wrong??? help please! Thanks!
BTW im using Revit 2009
Each element in cad that has a different material needs to be on a different layer. You then assign a material to that layer in Revit
Importing CAD to REVIT (vs. 2014) |
Mon, Nov 24, 2014 at 4:03:43 PM
REVIT'S POOR GRAPHIC DESPLAY WHEN IMPORTING AUTOCAD FILES |
Sun, Sep 24, 2006 at 10:37:21 PM
Importing DWG files |
Wed, Jan 25, 2012 at 10:45:57 AM
Importing CAD 3D |
Sat, Mar 7, 2009 at 7:26:45 AM
Importing 3D CAD Files |
Tue, Apr 23, 2013 at 4:29:30 PM
