Forums >> Revit Building >> Technical Support >> L-shaped counter in section
Mon, Mar 30, 2009 at 6:09:25 PM | L-shaped counter in section
ckchambe
Hello all,
Quick question...
I'm using the "L-shaped Counter" Family in the imperial library and am having some trouble with it's visibility in section.  In plan, my cut is slicing through the Horizontal side of the "L" and facing away from the vertical side, however, in the seciton view I'm seeing side of the counter which is behind me.  It looks as though I have a return floating in mid air.  I've been trying to mess around in the visibilty dialog in the cabinet family, but haven't gotten very far. Does anyone have any suggestions?
 THanks!
Mon, Mar 30, 2009 at 8:44:45 PM | L-shaped counter in section
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Change the Family Category to a generic model.
To do this go to Settings-->Family Category & Parameters and pick a different one.
By default certain family categories do not show as cut in section...
Regards,
Chris.
Tue, Mar 31, 2009 at 10:13:41 AM | L-shaped counter in section
ckchambe
Thank you!
counter top model
Mon, Feb 28, 2011 at 2:11:16 PM
Counter Top question
Tue, May 24, 2005 at 8:46:43 PM
Lower casework showing through when touching counter?
Wed, Mar 6, 2013 at 9:38:23 AM
Sink not visable when using counter top family
Mon, Aug 27, 2007 at 10:11:13 AM
Getting away from have Bench Tops/Counter Tops with Parametric holes for Sinks
Wed, Aug 8, 2012 at 6:51:22 PM
Page generation time: 3.9842
