Forums >> Revit Structure >> Technical Support >> Slab edges - square instead of plum?
Mon, Mar 30, 2009 at 2:37:54 PM | Slab edges - square instead of plum?
dlewy
Is there a way to make sloped slab edges square instead of plum much like you can do with a roof?
Mon, Mar 30, 2009 at 3:06:23 PM | Slab edges - square instead of plum?
4 Stars: 205 Votes
Like what?? images of what you want???
Mon, Mar 30, 2009 at 4:47:08 PM | Slab edges - square instead of plum?
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
there is the thickened slab edge which you can modify and add to the edge of your slabs; modeling tab; host sweep; floor slab edge.  is this about what your looking for?
Wed, Apr 1, 2009 at 8:46:05 AM | Slab edges - square instead of plum?
dlewy
I attached an image of what I'm looking to do. If you do a roof extrusion you can control this easily in the element properties, but I don't see it for slabs.
Wed, Apr 1, 2009 at 6:32:03 PM | Slab edges - square instead of plum?
esapc
You almost answered your own question.  Create a roof style with the components that you want for your slab and use the roof command instead.
Thu, Apr 2, 2009 at 7:58:19 AM | esapc
dlewy
Quoting esapc from 2009-04-01 18:32:03
The problem I've found with that (I've asked a collegue and he had the same results) is that even after adding the deck compenent it still doesn't show the flutes in section. Also, you don't get a span symbol. Any solutions for these two issues using the roof command?
Cutting floor slab edges out of pads
Mon, Oct 25, 2004 at 10:43:54 PM
Slab Egdes & multicategory schedules.
Mon, May 16, 2011 at 2:04:35 AM
Slab Edges
Fri, Jan 29, 2016 at 7:37:23 AM
Hidden slab edges not showing as desired
Wed, Apr 29, 2015 at 7:06:11 AM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
Page generation time: 0.1459
