Forums >> Revit Building >> Technical Support >> Grid Lines & editable dimensions
Mon, Mar 30, 2009 at 1:19:42 PM | Grid Lines & editable dimensions
DaveF
Hi
 I have a number of grid lines dimensioned up with a continuous line of dimensions.
On some, when I select a grid, the dimension figure turns blue & is editable which moves the grid.
On others it doesn't.
Do you know what is causing this & can it be rectified?
Hope you can help
Cheers
Dave F.
Mon, Mar 30, 2009 at 1:48:05 PM | Grid Lines & editable dimensions
BDerrick
3.5 Stars: 3 Votes
Dave, are you trying to lock your grids in place?  If so, click on the dimension string and lock the dimensions.  To prevent any accidental movement select all the grid lines and pin them in place. good luck
Mon, Mar 30, 2009 at 2:58:13 PM | Grid Lines & editable dimensions
DaveF
thanks for thereply. I realise I wasn't being clear enough.
I want to be able to move the grids, by the method I described above, but it only happen on a few of them.
Ta
Dave F.
Mon, Mar 30, 2009 at 3:17:53 PM | Grid Lines & editable dimensions
Dave - unlock your dimensions, if that doesn't work, look for a pin.
BTW - don't pin all your grids.  Pin one in each direction - then when you get your grid dimensions right - lock those.
Over-use of pins will get you in trouble
Mon, Mar 30, 2009 at 4:21:26 PM | Grid Lines & editable dimensions
DaveF
I don't have access to the model (it's late in evening where I am), but I don't remember locking the dims.
As they're a continuous chain I'm surprised some are editable & some not.
Mon, Mar 30, 2009 at 5:18:40 PM | Grid Lines & editable dimensions
Individual portions of a chain can be locked and I don't believe there is a way to lock the complete chain.
BTW - If a previous dimension was placed and locked and then the dimension is deleted, the lock could still be there.  Lock then unlock your dimension to eliminate this possibility if you are still having problems.
Mon, Mar 30, 2009 at 6:11:38 PM | Grid Lines & editable dimensions
jarosa
jarosa Avatar
4 Stars: 5 Votes
also make sure your dimensions are to the grid. if for example it's dimensioning the wall or column it won't give you the option to edit the dimension when you select the grid.
Grid lines moving together in different floor plans
Mon, Sep 20, 2010 at 9:10:52 PM
disappearing grid lines
Wed, Apr 19, 2006 at 5:44:48 PM
Grid line as centerline?
Mon, Jan 19, 2009 at 9:47:23 PM
Dimensioning grid lines
Wed, Aug 16, 2006 at 10:32:00 AM
Ignoring grid lines between independent structural systems
Thu, Nov 1, 2012 at 12:00:32 PM
Page generation time: 0.5283
