Forums >> Community >> Newbies >> Complete set of plans
Mon, Mar 30, 2009 at 4:46:18 AM | Complete set of plans
triskelion
Is there a way for me to produce a complete set of plans (i.e. drafting of the Structural, Plumbing and Electrical Plans) for the current project I am doing in Revit Architecture 2009? Or do I just have to draft and produce the aforementioned plans in autocad? Any work around in Revit Architecture? Thanks.......
"PRIMUM NIL NOCERE.........Man is brother unto man"
Mon, Mar 30, 2009 at 7:09:12 AM | Complete set of plans
We don't have a clue as to what your resources are or how complicated your MEP is but if I had my choice, I would do it all in REVIT.
Mon, Mar 30, 2009 at 8:15:41 PM | Complete set of plans
triskelion
Sir WWHub, what I'm driving at regarding my query as to the production of a complete set of plans is the the drafting of the Structural, Electrical and Sanitary or Plumbing plans of the project I'm doing right now. I have completed the Architectural plans of the project using REVIT Architecture 2009 and I want to do the 2D drafting of the Structural, Electrical and Sanitary plans of my project, using REVIT Architecture. Is there a way I could do these engineering drafting works by way of REVIT Architecture? Please advise.....Thanks.....
Mon, Mar 30, 2009 at 8:36:38 PM | Complete set of plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
We've modelled Structural, & MEP directly in Revit Architecture before the other platforms were available and whilst achievable its a bit of stuffing around.  If you are only 2D detailing MEP stuff then Revit is going to be more appropriate than autocad.  Revit can achieve most of what AutoCAD can in 2d detailing, if not all...
Regards,
Chris.
Mon, Mar 30, 2009 at 9:47:44 PM | Complete set of plans
triskelion
Thanks for the advice Mr. Spot. Does it mean that in the preparation of the MEP plans, I have to create different new projects using the same floor plan, this time without the architectural features, and draw 2D lines, using line pattern and line style, to represent rebar formations for the structural design, piping layout and electrical symbols for the plumbing and electrical symbols for the electrical and plumbing designs?
Or do I just have to duplicate a view of a floor plan where I would draw 2D lines to represent rebar formations or piping layout? Thanks for bearing with me.
Wed, Apr 1, 2009 at 7:14:59 PM | Complete set of plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If co-ordination is going to be of concern on the scale of the project then you should be modelling it all as it will help you in the long term trying to do manual co-ordination.
But yes, the latter option, keep it all in the one file and duplicate views/adjust visibility to create discipline specific views and draft the additional information relevant to MEP and Structural detailing with detail components, detail lines, symbols & text/tags.
Regards,
Chris.
Wed, Apr 1, 2009 at 10:25:08 PM | Complete set of plans
triskelion
Thanks a lot Sir Spot
Infill walls and phasing
Wed, Feb 3, 2016 at 1:05:59 PM
Complete brick steps
Tue, Dec 31, 2019 at 11:06:46 AM
Grid-head sizes set to be view specific?
Wed, Jun 1, 2011 at 10:15:22 AM
site plans and buildings plans
Tue, Apr 17, 2012 at 8:40:07 AM
Multiple Buildings - 1 Drawing Set
Wed, Jun 4, 2008 at 1:46:05 PM
Page generation time: 0.8436
