Forums >> Revit Building >> Technical Support >> Adding Parameter to Array destroys it
Mon, Mar 30, 2009 at 3:37:21 AM | Adding Parameter to Array destroys it
ant
ant Avatar
I'm trying to create a parametric array of shelves.
I've created a family object (a shelf). Nested that into my new family and arrayed it.
I locked the first element to the bottom ref plane, top element to top ref plane.
If I just move the top ref plane the array follows it fine.
If I put a dimension between the top and bottom ref planes and change the dimension it works.
If I replace that dimension with a parameter it works, if I change the parameter to another parameter with a different value it works.
But if I change the parameter value in the Family Types dialog box Revit complains and removes ALL contraints from the array.
Why would changing a parameter value cause it to break?
Edited on: Mon, Mar 30, 2009 at 3:39:45 AM
Mon, Mar 30, 2009 at 7:11:47 AM | Adding Parameter to Array destroys it
coreed
coreed Avatar
4 Stars: 16 Votes
maybe this link can help. look at post my Mr. Spot
http://www.revitcity.com/forums.php?action=viewthread&thread_id=15581
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:09 AM
Array Distance Parameter
Thu, Apr 11, 2019 at 8:53:57 AM
Centering an Array Parameter within a Family (Wall Based)
Fri, May 4, 2012 at 5:06:22 PM
Can't apply parameter to array number
Fri, Dec 3, 2010 at 5:24:22 PM
visibility parameter for array group?
Tue, Sep 11, 2007 at 3:11:24 PM
Page generation time: 0.5833
