Forums >> Revit Building >> Technical Support >> Revit crashes...
Thu, Jun 30, 2005 at 10:59:31 PM | Revit crashes...
jweber
Every time I try and do a decal REVIT gives me a "Fatal Error" and crashes??? Any suggestions?
Sat, Jul 2, 2005 at 10:35:53 PM | RE: Revit crashes...
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No idea, never experienced it. Ensure you have the latest build installed for a start. Is it a flat or curved plane you are applying the decal to and how large?
Sun, Jul 3, 2005 at 5:48:37 AM | RE: Revit crashes...
Xane
I never had that problem with 7 and 8, I had other crash but never with decal. May be try diferent bitmaps ...
Sun, Jul 3, 2005 at 5:49:37 AM | RE: Revit crashes...
Xane
Or attach decal we can try ...
Tue, Jul 5, 2005 at 4:01:54 PM | RE: Revit crashes...
lupinz
1 Stars: 1 Votes
i was using revit 6..and found revit frozed when i try to edit material property, i didn't know what the hack was going on, but after i switch to 7 and then 8..never has the same issue...but now....with revit 8...if u dont have adequate ram..it will just closed..yes, that's right...no warming window, no beeping, no asking if u want to save a recovery file..it just close the program..sigh...time to get more ram
Thu, Jul 7, 2005 at 2:35:03 PM | RE: Revit crashes...
pepsiqueen
pepsiqueen Avatar
try shutting off the open GL acceleration
Tue, Oct 17, 2006 at 9:51:11 AM | RE: Revit crashes...
wendyp
I was looking through the forum trying to get help with this same issue. I am working with a file that has grown very large. In an attempt to condense it a bit, I ran the purge utility on it. I have done work in it since, but recently found when trying to place a decal that it crashes. I have tried doing an audit, but it doesn't find any problem with the file. I do not believe the problem is with the image I'm trying to attach, because I don't get that far. As soon as I click on "decal" on the modeling tool bar, it gives a message saying Revit has encountered a fatal error and has to shut down. I have reported to Autodesk several times, but have gotten no response so far.
Revit crashes when placing keynote legend
Tue, Jul 25, 2017 at 2:07:43 PM
revit crashes when adding picture to page setup
Wed, Apr 28, 2010 at 2:37:21 PM
Revit 2010 Crashes when selecting the Big Purple R
Thu, Aug 5, 2010 at 7:18:26 AM
Revit crashes when selecting certain objects
Fri, Jul 7, 2017 at 11:20:56 AM
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards [ 1 2 ]
Sun, Sep 20, 2015 at 11:28:23 PM
17
Page generation time: 1.5791
