Forums >> Revit Building >> Technical Support >> Autocad Export - Page Setup Manager
Fri, Mar 27, 2009 at 8:53:39 AM | Autocad Export - Page Setup Manager
drawler
When I export the 24x36 (ARCH D) Revit sheets to AutoCad sheet files, the AutoCad page setup manager plot size is automatically set to "8.50 x 11.00 inches (Landscape)".  How do I get an AutoCad export that has the same plot size as the Revit sheet?
Fri, Mar 27, 2009 at 9:03:29 AM | Autocad Export - Page Setup Manager
drawler
By the way, I am using Revit Architecture 2008 and trying to export to Autocad 2004.  Thanks.
RVT to DWG export page layout settinigs
Fri, May 11, 2012 at 3:31:01 PM
Revit building in ACA 2009 project manager
Mon, Dec 15, 2008 at 9:08:31 AM
revit crashes when adding picture to page setup
Wed, Apr 28, 2010 at 2:37:21 PM
Page Setup
Sun, Jan 13, 2008 at 6:58:28 PM
Subcategories in export layer setup not displaying properly when exported
Tue, Jul 31, 2012 at 10:50:40 AM
Page generation time: 0.6004
