Forums >> Revit Building >> Technical Support >> Creating a special form - walls, roof and floors
Thu, Mar 26, 2009 at 4:41:11 PM | Creating a special form - walls, roof and floors
Jorgensen
Does any know if it is possible to create like the one illustrated in Revit ?
I have tried to create a solid - and then used "Wall by face". I can then create the form like shown on revit.jpg.
But I can't close the form by adding walls on the other two faces :-(
And I can't figure out how to give the form the twist / cutoff - like seen in plan.jpg.
Can anyone help ?
Thanks
Fri, Mar 27, 2009 at 6:25:12 AM | Creating a special form - walls, roof and floors
4 Stars: 205 Votes
"Does any know if it is possible to create like the one illustrated in Revit ? " - Are you kiding, right???? - Create in place in the category you want (walls, generic, whatever) in one piece...
"But I can't close the form by adding walls on the other two faces" - If you trying to create walls in TOP and BOTTOM of the object, of course you CAN'T, you CAN use ROOF or SLAB...
"And I can't figure out how to give the form the twist / cutoff - like seen in plan.jpg" - what?? the image with "blue floor"???? - simple, SOLID BLEND
YOU WELCOME....
Fri, Mar 27, 2009 at 4:42:24 PM | Creating a special form - walls, roof and floors
Jorgensen
Sorry - but can you explain how you would do it ?
I can't find the 'bend' tool you describe ?
It's not the image with blue background, but the one named plan.jpg that shows the 'twist'
Fri, Mar 27, 2009 at 5:17:17 PM | Creating a special form - walls, roof and floors
wheelergc
Solid blend is the tool you are looking for. With it you will set a bas and a top which can be side ways and REVIT will connect with a smooth blend.
Sat, Mar 28, 2009 at 5:57:22 AM | Creating a special form - walls, roof and floors
4 Stars: 205 Votes
Hi, see the video: 1º Video: http://www.megaupload.com/?d=IYNQ3R0G   2º Video: http://www.megaupload.com/?d=QZK3I8H0
Edited on: Sat, Mar 28, 2009 at 7:37:20 AM
Sun, Mar 29, 2009 at 7:51:31 AM | Creating a special form - walls, roof and floors
Jorgensen
@Typhoon
Thanks a lot. I'm honoured that you created such a detailed tutorial.
 I've got it made thanks a lot :-)
Sun, Mar 29, 2009 at 8:42:58 AM | Creating a special form - walls, roof and floors
4 Stars: 205 Votes
You Welcome, good for you....
aligning two curtain walls/panels in a Blob-like form
Wed, Jan 22, 2014 at 1:39:53 AM
How can I create a roof with the form of an Oak leaf ? Look at the .DWG attached
Sun, Feb 5, 2012 at 11:14:07 AM
Creating a roof that slopes with the walls
Sun, Feb 27, 2011 at 2:35:54 PM
How do you convert massings into floors, walls and roofs??
Thu, Jul 16, 2009 at 4:48:55 PM
Walls from multiple floors above showing in site plan
Wed, Oct 3, 2012 at 9:23:52 PM
Page generation time: 4.3999
