Forums >> Revit Systems >> Tips & Tricks >> Disconnect Switch
Thu, Mar 26, 2009 at 12:08:49 PM | Disconnect Switch
dlcraig
I have a 120V 30A disconnect switch that has been circuited to a panel. Problem is, on panel schedule, no load appears. I have tried adding an "apparent load" parameter set at 4600W. Still nothing. Help please!
Tue, Apr 7, 2009 at 10:34:00 AM | Disconnect Switch
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
i think this is a glitch in the software...i have had it happen many times and as much as i would rather just use the revit panel schedules i have to revert back to cad Sad try disconnecting and reconnecting the load or maybe even recreating the electrical system as a whole...not sure that it will work though.
http://familyjewels.typepad.com/
Disconnect switch
Mon, Aug 30, 2010 at 5:08:54 PM
Can't Disconnect Walls From Slab
Tue, Jan 19, 2010 at 12:08:14 PM
I can't assign a switch ID to a switch
Wed, Dec 9, 2020 at 5:42:46 PM
Switch ID Grayed out in Revit MEP
Tue, Feb 26, 2013 at 11:33:36 AM
How to create toggle-able annotation into a face based family for plan view only
Tue, Aug 23, 2016 at 12:03:51 PM
Page generation time: 0.0615
