Forums >> Revit Building >> Technical Support >> Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, Mar 26, 2009 at 10:48:01 AM | Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Livenrosecity
I am just beginning the journey toward understanding Revit families.
I created a parametric door frame using the Imperial Door Template with a parametric door panel loaded. The parameters for controlling the height, width, depth of the door frame seem to be working properly.
However, I do not understand how to control the position of the door frame relative to the centerline of the wall when the wall is thicker than the door frame.  One version of this door frame family aligns the face of the frame with the outside face of the wall when the wall gets thicker, and another version of the door frame family centers the frame with the wall centerline when the wall gets thicker.
I cannot figure out what I did to make the two families behave differently.  How to I control the position (alignment) of the door frame relative to the wall outside face?  Eventually, I will want to create a parameter to control offset depth.
The two door frame families are attached.
Thanks.
Thu, Mar 26, 2009 at 1:44:24 PM | Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
afc4
3 Stars: 3 Votes
See if these work the way you want. It seemed it was a simple fix where the frame wasnt attached to the walls ref. lines so when the wall sized changed the frame stayed the same size.
Thu, Mar 26, 2009 at 11:44:55 PM | Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Livenrosecity
Thanks afc4 for the response. Sorry for not following protocol; I forgot to mention that I am using Revit Architecture 2008, thus I am not able to open the files you edited.  Would you please post them again in 2008 format?
Wed, May 5, 2010 at 6:03:48 PM | Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
ollienz
ollienz Avatar
Liveinrosecity did you figure this one out in the end?
I am having exactly the same issue, ie what option/tickbox/method controls what the door face aligns with. It is locked to the wall centerline instead of the outer face.
Thu, May 6, 2010 at 7:29:41 AM | Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Create your door family around a placement work plane well outside the wall (like 12" ).  I would make the outside face of the door farme on the placement WP.  Then add an offset dimension and make it a label from the face of the wall to the workplane.  Change the offset dimension and watch the door move into the wall.
Edited on: Thu, May 6, 2010 at 7:30:04 AM
flip control only door panel & not frame/trim revit 2015
Mon, Apr 27, 2015 at 10:19:19 AM
Door Frame
Tue, Sep 28, 2004 at 5:58:51 PM
System Panel Door
Wed, Sep 29, 2010 at 9:55:55 AM
Best practice for scheduling door frame types when the frame is a curtain wall
Mon, Mar 23, 2015 at 10:49:57 AM
door frame off-set
Wed, Mar 11, 2015 at 7:42:20 AM
Page generation time: 0.7462
