18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Zero thickness wall layer
2 Posts No Rating |
My overall goal is to have a wall finish layer that allows me to capture square footage in a table, allows voiding areas of the finish, does not show in plan view, but does show hatching in elevation and 3D views. Our current wall family with a siding finish has a 1/2" thickness to the siding. It does everything we want, except that it shows in plan view. I can assign the siding layer to have a membrane function, and give it a zero width, but I can't get hatching to show on a membrane layer and I'm not sure how I could void out the membrane layer on areas of the wall where I don't want the finish. Any thoughts? Thanks.
----------------------------------- Bobby C. Jones |
Make the finish layer smaller (1/32" . Don't use a membrane layer because the more you use thing for reasons that they were created the more incompatable your file becomes for future users.
Christopher Ganiere, NCARB, LEED AP
www.developmentone.net
Skype: ArchitectCRG |
Sounds like the only "correct" way would be to model the finish layer as its own wall. - You can then give these walls a property as finish to enable you to filter them from displaying in plan
- They'll show fine in elevation
- Can get all there areas
- simply join them to the main wall and they'll automatically inherit the same cutouts for windows and doors...
HTH.
Regards,
Chris.
2 Posts No Rating |
Hey guys, Thanks for sharing your ideas. I have tried assigning the finish a very small width, but the smallest that I could get was 1/16", just enough to ensure that somebody would snap a dimension to the finish instead of the stud and sprinkle the plan with 1/16" dimensions. Ever the optimist, I started with 1/256" and doubled the number until Revit took something, which ended up being 1/16". And thanks for the tip about joining the walls. That's going to come in very handy.
Errors using Membrane Layer: zero / non-zero thickness |
Wed, Aug 7, 2013 at 6:08:50 PM
change layer thickness |
Tue, Oct 27, 2015 at 7:51:57 AM
How to control a single-layer wall? |
Wed, Apr 28, 2010 at 2:39:50 AM
Kenoting a Membrane Layer (0" thickness) |
Sat, Feb 12, 2011 at 12:23:27 PM
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
