Forums >> Community >> Newbies >> Dimensions on unparallel walls
Thu, Mar 26, 2009 at 5:52:30 AM | Dimensions on unparallel walls
triskelion
Please help me on how to put dimensions on unparallel walls.Your help would be very much appreciated. Thanks.
"PRIMUM NIL NOCERE.........Man is brother unto man"
Thu, Mar 26, 2009 at 6:51:21 AM | Dimensions on unparallel walls
4 Stars: 205 Votes
Try this: select dimension then pick in the first wall, go with the mouse to the other wall and click with the "TAB" key until you select the point you want....
I hope this help.....
Edited on: Thu, Mar 26, 2009 at 6:52:06 AM
Thu, Mar 26, 2009 at 10:07:31 PM | Dimensions on unparallel walls
triskelion
thanks typhoon i'l be working on it.
Fri, Mar 27, 2009 at 12:27:26 AM | Dimensions on unparallel walls
DimensionHelper
You cannot dimension on unparallel wall faces/centers, but you can always dimension to corners of unparallel walls. see image attached for example.
If it doesn't work for you, let me know.
Mon, Mar 30, 2009 at 1:41:09 AM | Dimensions on unparallel walls
triskelion
thanks......
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
dimension between 2 unparallel walls
Thu, Jan 18, 2007 at 11:09:41 AM
13
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Maintaining interior dimensions when changing walls
Mon, Mar 16, 2009 at 11:19:25 AM
Inclinanated wall dimensions
Fri, Apr 25, 2008 at 10:18:55 AM
Page generation time: 1.9525
