10 Users Online (8 Members):
Forums >> Community >> Newbies >> Revit MEP 2009 - Vertically stacked devices (families) overlapping
2 Posts No Rating |
i was wondering if there is a solution for vertically stacked items that appear on the same wall. ex: wall receptacles that are directly beneath one another but at different elevation heights. on the plan view it appears the receptacle symbols are overlapping each other, and it becomes a mess. when you offset the symbol off the wall, the 3D model follows it creating an incorrect elevation view. basically, the rough-in view of the wall box is following the 2D view of the symbol. any way around this? -howard p.s. ive tried creating a parameter called "symbol offset" and using a dimension bewteen the 2D symbol and a reference plane, but the symbol still automatic snaps to a wall and will not leave the surface it is mounted to. when you go to offset it, again the 3D model follows
2 Posts No Rating |
nvm. i found a solution. the symbol was an 'annotation' i had to edit the family that the actual symbol was bound to. adding an offset parameter for the symbol alone was the key. this may help anyone that designs rough-ins and has the challenge of populating condense areas or places where devices stack vertically. thanks for the help P
8 Posts No Rating |
Find below given link about vertically stacked partitions: http://revittut.blogspot.com/2006/10/vertically-stacked-partitions.html Let me know if it can be os any help.
Revit MEP 2011 crashes when circuiting electrical devices. |
Thu, Jan 27, 2011 at 9:27:58 AM
vertically stacked walls |
Wed, Jan 26, 2005 at 8:48:43 PM
No NUrsecall Familes In revit Mep 2010?? |
Tue, Oct 22, 2013 at 12:37:01 PM
ID Numbers and Unasscoiated Families In Revit MEP |
Tue, Nov 29, 2011 at 12:12:18 PM
Electrical devices not hosting?? |
Thu, Jun 11, 2009 at 10:43:01 AM
